CherryK5
Is that a sign of bad rings or am i just in need of an oil change.
I have a castrol synthetic oil change waiting for me
Is it carbed or FI? If it is carbed then you might have a bad fuel pump. Sometimes when the mechanical pump fails the diaphram will dump fuel into the crankcase.
Assuming it is a carbed engine, it is probably the fuel pump leaking into the oil.
Edit: Damn Scott beat me
.As long as you get a regulator and ensure you aren't forcing too much pressure up there. Too much pressure and you will flood out because the needle will never close. Mechanical is cheap, easy, and easy to replace. For the cost of setting up a quality electric, you can do several mechanical pumps.
Damn the both of you. I saw this title and i was so excited to come in and answer this then i open it and see 2 other people already had my answer.
Try your fuel pump first, if thats not got it then ...What Shady said.the gas i had in my oil was due to incorrect float settings. It would dump gas in the carb and down into the cylinders after I shut the engine off. gas sitting in the cylinder over night will leak into the oil
