Sold Price Drop! Ruffstuff El Dorado Calipers and ORD brakelines
cheavyk10
What, me worry?
Centralia Washington
Up for grabs: Almost new Ruffstuff El Dorado Calipers, with parking brake, pads and bolts, and matching Off Road Design soft brake lines. Only maybe half a mile on these. These are for trucks with a 14 bolt disc brake conversion.
So I installed these on the truck, had to grind them slightly for my 15" rims, and had no brake pedal after I bled them. I had to go on a trip with this truck the next day so I swapped back the original calipers I had on there. If I had read the instructions I would have saw that you have to adjust them with the bolt under the lever arm before you bleed them. So I never got around to reinstalling them so my loss is your gain. Been sitting on the shelf for awhile.
$150 + $15 USPS flat rate shipping.
IMG_20211127_161629131~2.jpgIMG_20211127_161713552.jpgIMG_20211127_162141906.jpgIMG_20211127_161652865~2.jpg
I also have the extended wheel studs for thick aluminum wheels I would be willing to part with.
Hmm I had better not right before Christmas. If you still have them kicking around in a month or 2 I'll definitely shoot you a PM
Let me confirm fitment since my truck is kinda Frankensteined together thanks to the p.o
and well me too lol
80's style o-ring. I was thinking about springing for a redhead, with the pre tapped ports. But I was also looking at diy4x's end cap for hydro assist.
I'll double check what is on the shelf tomorrow. I usually sell the used boxes for $40-50 assuming I know they are good, so not a straight trade. But I need to double check i have one with the correct fittings.
