prob putting 52"s in the front...HELP
owen
Brewton AL
prob putting 52\"s in the front...HELP
I was moving my spring mount forward with all the guidance from past posts, but the front of the frame is cut off (factory) at an angle, which doesnt give me much if any room to drill for the front bolt on the bottom. If yall cant follow this, please tell me how to post a pic. I cant find any help on that in "search" either. /forums/images/graemlins/dunno.gif
Re: prob putting 52\"s in the front...HELP
I could not drill either as I have a welded in support there. You can bolt on everything you can and drive it to a weld shop to run a bead for you. I dorve mine around like that. I dont think missing one bolt is a big deal for a little bit.
I even went out and tested the flex without the front bolt and without the L part out on yet.
thanks- I just needed a little confidence, which you have provided. What I think you said was "just go ahead and drive the wheels off tha' thing and dont worry about it"- and thats exactly what I am going to do! you the man /forums/images/graemlins/peace.gif
