COCHEV
so same rig as my other post about distrib. weights- pickup with newer crate 350
in addition to my oil change i pulled the manie and put new gaskets on it cause they were leaking badly. also did the valve cover gaskets while i was at it.
got everything buttoned up and topped off with new oil= delo this time- i use it my big block and its great
however, now i have this valve noise. its only on the pass side. its almost like a thumping. i can feel it when i put my hand on the valve cover. and it speeds up with rpm.
my fist thought is that the rockers are some how hitting the cover. i pulled the cover and could see no signs of that...
stock covers, stock stapped rockers.
its pretty audible and i can feel it in that valve cover. does my motor not like the delo? my machinist recommended it and i've been useing it very successfully in my big block ever sense i did a cam swap on it.
maybe a rocker stud comingout? stuck lifter? any suggestions???
stock covers, stock stapped rockers.its pretty audible and i can feel it in that valve cover. does my motor not like the delo? my machinist recommended it and i've been useing it very successfully in my big block ever sense i did a cam swap on it.
