marko
I NEED HELP I HAVE A INTERMITTENT CLUNKING IN FRONT END ITS AN 1989 K5 ALL STOCK. SHOULD THE FRONT SHAFT SPIN FREELY WHEN IN TWO WHEEL DRIVE? THERE IS NO SPECIFIC TIME THE CLUNK COMES AND GOES. THIS IS MY DD SO ANY HELP WOULD BE GREATLY APPRECIATED. IT STARTED YESTERDAY WHEN I WAS DRIVING IN SOME TRAILS IN TWO WHEEL DRIVE NOTHING EXTREME AT ALL. PUT IT IN 4HIGH AND 4LOW AFTERWARDS NO PROBLEMS OR NOISE AT ALL. PULLED HUB CAPS AND EVERYTHING LOOKS NORMAL DRIVER SIDE SEEMS TO HAVE LITTLE MORE PLAY THAN PASSENGER BUT NOT MUCH. ANY IDEAS.
was this the first time you went off road?if so i'm guessing lack of use.mine went when it was a DD. use it or lose it. i went years without locking the hubs.then i expected them to work when i did.
Very easy swap to do, take maybe half an hour.
