Been a while but If its like my 95 2500 4wd then on the pass side of the front axle theres a vaccum operated switch with small plastic vac lines to it thats obvious,otherwise it would be just a straight tube like a normal hub setup to the end where the knuckle is. If im not mistaken a brake job in front does not require touching the outer axle, if it did the inner where the diff/axle seal is isnt disturbed anyhow as the axle is 2 sections with their own respective seal setups. If the outer axle must come out its a PITA due to the single cartridge type wheel bearing held in by the 12pt bolts on the inner side of the backing plate.
Personally I cant see the seal literally falling apart that quick,seapage and small amounts of leakage wouldent stop me from driving it anywhere until I had the time and motivation to remove the axles,and carrier simply to replace a $2.50 seal,its a time consuming job to say the least. My 95 had continuious probelms with the seals,axle U joints and bad ball joints,seems to be another Dodge thing for some reason. I see that somebody makes some pretty high tech cartridge type inner seals for them and also while in their Id replace the axle joints with some good quality spicers as well as check the commonly failing ball joints and use MOOG ONLY. Do it all,do it once the right way,You`ll be way better off, DAHIK.
