In my copious spare time (heh) I'm working on a new desert truck (Sad Suburban build). This one's an '85 Suburban outfitted for long range camping trips and totally focused on expedition style trips without the gratuitous rock crawling and such. As such, I'm building a Turbo Diesel to put in it for reliability and fuel efficiency for resulting longer range. The exhaust manifold is a Banks Sidewinder, and right now it's the final turbo fitment that's causing issues.
This Banks turbo exhaust manifold flange appears to use a proprietary 3 bolt trigon flange. The flange is very close to a Walker 31305 gasket (link to specs), but the hole is at least roughly 1/4" too large (pipe is 2"), and the bolt holes are about 1/16 too far out. I've got that gasket and modified the bolt holes to fit, but that leaves very little (less than 1/8") between the bolt hole and the gasket hole.
The OEM Banks crossover flange was removed from the old tube on the lathe and the old weld beard turned down to more or less what it looked like when first used. It was warped pretty good, so I stabilized/averaged the flange face with shims to surface grind the back side flat, then flipped it using the now flat back side as a reference to grind the face with minimal removal. It took about 0.008 to clean the seating area, leaving the ears just a bit low (which I think is good). But then I had to weld it onto the new custom crossover pipe taking pains to minimize warp, which certainly warped it again to some degree, though I doubt near as badly.
FYI: The Banks gasket I got with the manifold and crossover was clearly leaking pretty badly between the flange ears on one side. Hard to say if warped by being installed by gorillas with impacts, or welding, possibly both.
So I have 2 question:
1) I know lots of you guys work in different industries. And while I can't find an automotive number that matches the Banks flange, I'm betting that Banks didn't actually have short runs made JUST to lock customer into their "only way to get it is a kit that will cost over $55 shipped". That kit only contains 2 non-common/cheap gaskets, and this is one of them. So if any of you have suggestions for other sources where I can look I would much appreciate it.
2) Given that the flange has certainly warped to some degree, and it's utterly impractical to resurface after welding, it really needs a good crush gasket. The banks unit appears to have a crush ring in the ID of the main gasket, but the Walker gasket is just a steel/fiber flat gasket with no ring. I don't have great hopes for it holding, and it's not an easy gasket to replace. I've got ultra copper high temp RTV, but given that Turbo EGT's routinely hit 1000+ *F, I don't have much hope of that holding up. What would you guys suggest to help that gasket hold?
I think the copper will work fine with the flange since it can handle the heat
