Look at the back of the cluster. Find the three copper strips that feed the oil pressure gauge. Figure out which is power and which is ground (both power and ground are normally shared between multiple gauges and lights), which then will leave the one that is the sending unit wire.
Need a pin for the instrument panel (IP) connector pigtail out of the wrecking yard or wherever, and solder your sending unit wire to that, and put the pin in the correct cavity in the IP connnector.
Now, that is assuming that ALL of the rest of the wiring is the same between the two clusters, and I suspect it's not, that the IP connector may need to be rewired for the newer cluster. You have to compare the two printed circuits to figure it out.
