PsRumors
New setup. Rebuilt 205 behind a rebuilt 4l80e. I can't seem to get the transfer case to do anything other than shift between 4 wheel drive and neutral.
What do the shift rods look like for each of the gear sets? As best I can tell if both shift rods are pushed all the way in would be 4 low. Both one click out would be neutral. Then the rod that controls the rear would be one more click out for 2 hi and then the rod for the front would come forward for 4 hi.
Is that correct and does that make since?
