84gmcjimmy said:
powermad, thanks for that. I will try what you suggested, and now I know what parts I am dealing with. I'm going to try to do it either today, or maybe monday. So if I get it I will post up. I also have to jack the front up, someone suggested that would be easier to get the steering box on the frame so I can get the draglink/pitman arm apart!
I think I have a haynes and a chiltons manual, I didn't think they would have this in it though? woops. I will find that today and study it for whenever I take it apart.
Thanks for all the help.
I suggested ya raise the front wheel to remount the steerbox in your other post.
It can be sorta awkward and be a PITA if ya don't.
With the wheel raised you don't fight it as much going back up.
You just need to get a couple of bolts back in it, just enough to support it so you can remove the draglink.
Getting a repair manual would be a wise investment at this point.
Oh and the Harbor freight flyer had a set of ATD pickle forks. $28. 3 prongs, 15/16", 1 1/16" and 1 1/8", with 2 interchangeable handles. One for beating on with a hammer and another for an air hammer.
I would take that fork back and get a set elsewhere. That's pretty spendy for just one. Unless it says Snap On.
Generaly I can remove a TRE (Tie Rod End) with out damaging the boot with a fork.
And if I am hammering on the fork hard enough to damage the boot the situation has switched to drastic and a 9 pound hammer is involved and will require another end anyway.
Thanxs to TRW I have lots of time removing TRE's
Of course OTC makes a tool for removing lil TRE's that works pretty slick, I think I paid $60 for it. Universal tie rod end press
I did find that my Snap On pitman arm puller works excellant on the big TRE's at work.
The OTC press does not fit over the pitman arm though, if cracking the end of the arm doesnt pop it loose then a fork will be needed.
Tap the fork in till it is nice and snug and then smack the nut.
Remember to turn the nut over and run it down. That gives a nice striking surface and will protect the threads if ya plan on reusing it.
The Snap On fork Harley posted is the one I use to remove TRE's, draglinks and ball joints from light duty rigs.
