I have a 77 Chevrolet 3/4 ton with a older 305 or 350. Heres my problem when I go to start it after its been sitting for a day I have to pump the pedal several times to get it to start. When it warms up it starts fine only when it sits a while is when the problem starts. It seems like the fuel drops back into the tank.
, also when its cold and you pump the gas that is what activates the choke and high idle lever, as it was more than likely parked warm and the choke was open.
