K5dreamer
Hey all, its not the blazer, but it involved wrench spinning, and i know most of us have vehicles other than the K5's in our lives sooooooooo i thought id share.
My other car is a 2000 Jetta TDI. It has the famous yellowing, sandblasted, ugly headlights. Ive been toying with buying new ones, getting aftermarket projector headlamps, or something else. But those are normally hundreds upon hundreds of dollars to fix.
Instead, the last time i was at the VW parts department my guy fred suggestd the 3M Headlight restorer kit, he had started carrying it for people with my problem. so i figure what the hell, its $17 bucks, lets see if it works. Ive used headlight "cleaning" kits before, that were mail order, using sandpaper, and were piss poor performers. but this was name brand, so i figured id give it a shot.
A picture is worth a thousand words so......
Before using the kit (sitting unsanded, as they were removed from the car)
AAAAnnd after.... keep in mind, these are the same headlights, not new units.
This took a bit of time, i did 5-7 passes with the 500 grit, 3-4 passes with the 800 grit, 2-3 passes with the 3000 grit foam sanding pad, and 2 passes with the foam polishing pad, then wiped the lens clean with an old t-shirt.
very much worth the $17 i spent on it. just for more fun pics......
Now I'm going to have to give it a try on my step moms avalanche.
