Brand new
Was bolted up, then taken back off. Didn't realize it doesn't have an EGR. So never technically "used".
I have the bushings, square bore adapter plate, and heat riser choke block off plate w/bolts and gaskets. I think I might have an extra set of intake gaskets as well, but not positive.
fits 87-95 iron heads using supplied bushings
fits older style heads as well without bushings
was on 400sb with newer heads
Paid for it new. Looking for offers.
http://www.summitracing.com/parts/PFS-52000/
I have the bushings, square bore adapter plate, and heat riser choke block off plate w/bolts and gaskets. I think I might have an extra set of intake gaskets as well, but not positive. fits 87-95 iron heads using supplied bushings
