Project: Dirty South (K5)
xanthias
Houston, Texas
I picked up a 1983 K5 from a local friend a few months ago. I grew up on Chevrolets as a kid and I've always had a fondness for the Big Iron rigs.
"Dirty South" is how I think of the project as a concept - basic, nothing fancy, but done right and has it where you need it:
Let's start with the baseline specs of the rig:
1983 Chevrolet K5
350 V8, currently carbureted with an Edelbrock Model 1411 Performer 750
700R4 "Raptor" Transmission
NP208 slip-yoke
10-bolts, 4.56 and locked
Home-brew big iron bumpers
Dual-battery setup with 200-amp Powermaster alternator
Tuffy Security Console
By the by, anyone looking for a good part number list for these rigs can find one here:
http://coloradok5.com/forums/showthread.php?t=53116
When the prior owner got her many moons ago -
And, how she looked when I got it after she had been sitting for quite a few months outdoors with no top -
You can see here the extremely sturdy rack made for it back in the day. The rack had a transmission sitting on it right before I took this shot. This will be reworked and retained into a new bumper setup.
Among the many luxuries are a busted column due to no key and the always obligatory rat's nest of wiring under the dash. A bonus is no key for the Tuffy, either. However, if you call Tuffy Security Products and give them the lock number, they will send you a whole new lock and key assembly for about $11. Problem solved, once we man up and drill out the old one.
Truthfully, the floors are in much better shape than I expected but outdoor living kicks the wee out of the 80's Chevy sheetmetal.
Rockers are toast - no surprise. They're getting cut out for sliders anyway. There is also some rust penetration around the door drip rails. It's minor enough that a few mig tacks should take care of it. All of these interior pics are after the soggy interior and carpet was gutted, which was a fun job on its own, sort of like gutting a moldy pig.
Engine bay is in pretty good shape, considering how long it had been sitting. A large screwdriver, some brake cleaner and I had to join forces to convince several colonies of dirt daubers to move on, but otherwise we were open for business.
Moveable feast?
The first item of business was to get it moving under its own power sufficiently to get it on a trailer. Before I even bothered starting, I spent about four hours power washing it, as my buddy had, shall we say, ridden her hard and put her up wet the last time out.
We had several "opportunities" facing us here. To summarize, we had a flat tire, some pesky fuel issue and various battery mis-adventures along the way to getting her to turn over.
I dropped the rusty factory tank (an adventure all its own, since you have to drop the rear bumper to get to the tank strap bolts) and swapped in a fuel cell that might look familiar. What's more fun that wrenching in a field?
We then had to deal with the Edelbrock -
A stuck float, clogged jets and loose linkages were fairly easily remedied.
Let me pause for a minute on the subject of the lowly Edelbrock. It won't be staying on this rig, but I would be remiss if I didn't provide some tech on improving their off-road capabilities. Rumor has it, with some float and off-road jet changes, they can be made to approximate a Holley Truck Avenger.
Edelbrock Off-Road Modification How-To:
http://coloradok5.com/forums/showthread.php?t=161779
http://coloradok5.com/forums/showthread.php?t=162851
That done, we finally got the trusty 350 to turn over and it was trailer-time -
Here, you see me navigating past my friend's 1-tons, which he is thoughtfully allowing to rust away as a monument to the now-departed K5.
Unfortunately, we got distracted about a mile up the road from my bud's shop at a local icehouse, so work stopped for the day, strangely.
Let's get to it
Before we drug it over to my friend's shop, where it will now be in his way for many weeks to come, I had been working away in my own little lair on smaller projects and acquiring parts.
First, I addressed the busted column issue by buying a 1982 manual column with tilt from Greywolf and rebuilding it.
Tech and parts for the column rebuild -
http://www.texas4x4.org/showthread.php?t=18823
I went with a manual column because I plan to install a floor shifter.
For the axle swap, another friend was kind enough to supply me (in exchange for money - go figure) with the 1-ton's out of his old rig, Rusty (http://www.texas4x4.org/showthread.php?t=15694). Specifically, a Dodge king-pin Dana 60 front, sourced from a 1991 or 1992 Dodge 1-ton truck. The axle has been fitted with hi-steer, using Koz Offroad hi-steer arms. It is welded and has 5.86:1 gears. It is currently set up for coil springs and links, but I will be going with leaf springs (52's). It has a "well-loved" 1350 yoke. The differential cover is a DIY4X Razorback, which has been thoughtfully powder-coated "oh crap" orange. The axle still has stock 30-spline outers.
This is what the Dodge 60 looked like soon after he completed it and before he drug it all over Hell's Half Acre.
The tie rod is beefy enough to use as a boat anchor. I'm assuming he stole it off a bulldozer or something.
The Dodge axle is full hydro with a Tractor Supply 2x8 ram. So, I also picked up the full-hydro setup from him, which uses a Chevrolet saginaw style power steering pump (that will bolt right up to the 350) and with the DanFoss steering valve:
The rear is a Ford Dana 60, sourced from a 1979 or so F250 and it is also welded with 5.86's and a 1350 yoke. A bonus is the disc brake conversion has already been done and he even used the foo-foo Caddy calipers with Eldorado discs. The differential cover is also a DIY4X unit with matching "burn your retinas out" powder coating. This axle was also set up for links and coils, but that will also be reverted back to leaf springs (63's).
The seller already managed to snap a shaft previously (now replaced) in his light truggy, so I'm very skeptical about the 30-spline axles in the rear. Alloy replacements are available in 30 spline:
http://www.dutchmanms.com/pricesheet.html#Anchor-65138
http://www.moserengineering.com/Pages/Axles/customalloy.html
Many argue they aren't worth the money for what benefit they add and the only real solution is to go with 35-spline. To do that, you will have to bore the spindles to accept the thicker, 35-spline shafts. Edit - I understand there are now some 300m 30-spline shafts on the market.
Because he is a prince among men, he also tossed in the drive shafts, links and rod-ends. My friend helping me with fabrication has ideas for those, since he knows my hillbilly ass is insisting on going back with leaf springs.
Parts a go-go
Now, before everyone starts flinging poo because I want to go back with leaf springs, I offer the following in my defense:
6" shackles from Kert at DIY. You can get these cross-tied, but I can't imagine why you would need that - these are beefy. Since I will be doing a 52" spring swap (i.e. the stock 52" rear blazer springs will be swapped to the front) and I plan to retain the stock, trailing front spring mounts, Kert thoughtfully welded in the necessary spacers on the shackles to match the spring width correctly.
You can buy these shackles separately, or bundle them with a couple of "kits" from Kert, which is what I did.
First, the "B52" kit for the front -
http://www.diy4x.com/suspension.htm
#00226k6 (with 6” shackles) - $190.00
Tech for 52” Swap:
http://coloradok5.com/forums/showthread.php?t=148725
Second, the shackle flip-n-switch kit for the rear -
Both kits come with all the mounting hardware you need. To use 63's in the back, as I plan to do, you will not be able to use the stock trailing spring hanger mounting holes for your flip-n-switch. You will have to drill new ones farther back on the frame.
Tell me this isn't electric sex -
#00120KB (with 6” shackles) - $195.00
This stuff was so heavy, I figured out Kert's packaging is not to protect the contents, it's to protect the handler.
Yet another wheeler supplied me with a used set of 63" Chevrolet springs in excellent shape. These suckers are looooong and you can actually flex the main leaf my hand if you stand them on end.
Finally, what to do about the spring perches, u-bolts and shock mounts. Enter RuffStuff Specialties' Simple Axle Swap Kit -
U-bolts are included pre-bent with the proper washers and tall nuts. There are only 7 because the inboard spring perch on the Dodge axle cast spring mount uses studs.
Those spring plates are 3/8" thick - insane. They also have oblong holes for the u-bolts, so you can accommodate adjustable mounting surfaces for your spring pack centering pin.
These spring perches have 3 choices of holes for your pack centering pin so you can center your axle how you want.
Shock mounts, front and rear.
This kit was basically $86 for the front and $110 for the back. If you can beat that, I invite you to do it. Dan also was awesome with customer service, immediately shipping me a duplicate order when the USPS lost the first shipment. The parts are beefy and well-made. I'm assuming Dan must have an army of Oompa-Loompas chained in the shop as forced labor.
Parts a go-go
Steering
I need a way to go from a Chevy column to the DanFoss steering valve so I turned to Station at POR (Performance Off-Road Systems):
Basically, what you see here is POR's Straight Spline Adapter: ¾” Female Tube to ¾” 36-spline female ($20.50) and the Orbital Valve Input Shaft: ¾” 36-spline male to ¾” 12-spline male ($55.00). Total to me was $83.50. All I need is ¾” tube to fabricate intermediate steering shaft, so you can see this will work with just about any steering column setup.
I wanted to go this route so I could retain the stock Chevy column and mount the DanFoss down on the frame roughly where the steering box is now. There are other ways to do this, including some slick firewall mounting systems. Summit can hook you up with mounting bracketry if you want to go that route.
Also on the steering topic, I laid in a steering fluid cooler to plumb in-line -
This is NAPA P/N 1-4823 Oil Cooler $59.99. It is rated for like 23k pounds as a transmission cooler.
Rust
For the body rot, I got this:
http://www.rustbullet.com/ProductCart/pc/viewPrd.asp?idcategory=120&idproduct=416
Application Instructions:
http://www.rustbullet.com/Application.htm
This stuff is supposed to be the bomb on killing rust. I will report back with my results.
Shifter
As I mentioned above, a floor shifter will be used instead of the column, so I will go with a B&M Light Truck Megashifter -
This is part number #80680 and you can find it at:
1. Jeg’s #130-80680 $197.99
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_745755_-1_10517
2. Summit #BMM-80680 $199.95
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM-80680&N=700+115&autoview=sku
Or, like I did, you can win it on eBay from Speed Unlimited Sales - $189.88 with free shipping.
Installation instructions (PDF):
http://www.bmracing.com/media/products/pdf/10.pdf
Carburetor
Last but not least, the Edelbrock is going to be replaced in favor of a Holley Truck Avenger 670 -
This is also widely available at:
1. Summit #HLY-0-90670 $429.95
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY-0-90670&N=700+115&autoview=sku
2. Jeg’s #510-0-90670 $421.99
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_71888_-1
Or, again, I got mine off eBay from Atlantic Speed Warehouse, Inc. $340.88. This included free shipping, a t-shirt, stickers and a Holley fuel pressure gauge. It was new in the box and came with a very helpful tuning and installation DVD.
Specs -
http://www.holley.com/types/Truck Avenger.asp
http://www.holley.com/0-90670.asp
http://www.holley.com/data/Products/Technical/199R10268-4.pdf
Now, a couple of important notes here. If you are going to put on a carb, then they are going to nickel and dime you to death with linkages and such that you need to set it up right, particularly with a 200R4 or 700R4 transmission, which MUST have the TV or transmission kickdown cable installed and properly adjusted.
Linkages, etc. (prices from Summit Racing):
HLY-20-121 Transmission Brackets and Levers, Steel, Gold Iridited, Buick/Chevy/Oldsmobile/Pontiac, 700R4/200-4R, $25.99
HLY-20-38 Throttle Lever Stud, 1/4 in. Stud, Universal, $5.95
HLY-20-40 Throttle Lever Stud, 5/16 in. Stud, Automatic Transmission Kickdown, Universal, $6.95
HLY-20-95 Throttle Cable Bracket, Steel, Gold Iridited, Chevy, Big/Small Block, Holley, 4150/4160, $19.95
TV Cable Adjustment Tech:
http://www.700r4.com/faq/whattv.shtml
http://www.tvmadeez.com/article/index.php
Tuning and tech:
http://coloradok5.com/forums/showthread.php?t=174116
Strip-tease act begins
Rear 60 gets Y-link and coil buckets stripped -
Doors off and seats out -
The child's seat will be used for mockup when the cage goes in.
Bumpers off -
let me tell you, greg had a project sami that he had to sell to make room for his future wheelers (3 young sons); and if he puts the detail into this like he did the sami, it is sure to be real nice for sure :bow:
Well, Jeff is being a little generous with the praise, but if there are any closet Sammi fans here, you can look over that old project here:
http://www.texas4x4.org/showthread.php?t=7470
Hey I've seen that truck before. Wasn't that brian's? I know him as Bent & Twisted over on RamChargercentral.
Exactly correct. One in the same. Sharp eye! :bow:
Now, tell me all the horrible ways he wheeled the wee out of it . . . :eek1:
He's got a sweet, fully topless Ram Charger in his garage, currently serving as a storage shed for his wife . . .:laugh:
Nice build so far. With the 63" springs in the back, are you going to leave the front spring hangers in the stock location and just move the rear back?
At the moment, that is what we are thinking - leaving the leading rear hanger in place and move the DIY flip from the usual location utilizing the factory mount holes to further back on the frame. I suspect we will have to mock it up to be sure everything will work.
Now, I'm off to spend some money with ORD for all greasable bushings and bolts.
Subscribed! Looking forward to this build. Really appreciate your attention to detail and the fact that you list everything from part numbers to prices on stuff. Talk about thorough!
What part of Houston are you in? I'm pretty close to the Galleria.
ohhhh aahhhh! very cool man, good looking project for sure. i really want to see how this turns out.do you by chance still have those ten bolts?
Scrounging up parts is the biggest part of every build. I'm glad to try to give back some tech. I'm in Kingwood and the shop where the Blazer is under construction is in Sealy.
Yessir, haven't been touched yet. I can verify they drive and are locked.
