K5dreamer
Ok... so yall know ive got that D70HD, and i want disk brakes, with a parking brake feature.
SO i bought the SRW hubs off a 1998 G-van, and im harvesting the drum-in-hat brakes from a 2000 GMC Sierra 2500 2WD truck. The rotors will bolt to the back of the hubs old school style, instead of slipping over the outside of the hub like newer style axles. and the backing plate and caliper bracket will bolt to the D70HD with some sort of as yet unmade adaptor. Giving me big dual piston caliper brakes, and a fully functioning factory parking brake setup.
Heres my question. I want all my lugnuts to be interchangeable, same threads up front as in the backs. the SRW hub i got off the G-van has metric bolts. running the numbers the wheel bolts i have have a "Knurl diameter" of 0.625 inch. while the wheel bolts i want to put in from the older K30 have a "Knurl diameter" of 0.621 inch.
is that a major issue? 4 thousands of an inch? would the older style wheel bolts be too lose in the new style hubs? do i need to go find a 14bolt axle with the drum bolted to the back of the hub in order to make everything work?
