project go fast..78 vett
moving along, today was degreasing the wheel wells, crossmemebers and rear frame and front outer frame and brackets. Primmed then used 3m splatter/wheel well paint. Then taped off again and painted the trim black on the the appropriate parts
more finished pics, the 3M stuff aint cheap but its so far the best out the 3 brands I have used. Also got the rear axle drive lines back, rebuilt, balanced and u-joints.
next on the list is ordering some specialty tools to rebuild the rear trailing arms, new calipers, rotors, backing plates, brake lines through out the car and bearings.
The a-arms and front springs will be removed when go through the front suspension parts so i didn't bother cleaning them up since they will get powdercoated anyways. Same with the rear trailing arm parts assembly.
