dave_90_blazer
ok, here is the plan
90 Blazer, has LT1/700R4/241/F10B/R10B, has a 4" lift now(front springs, rear blocks)
right now I am doing some rust repair, so this stuff will be later this year or so
ok, I will be getting some good tread super swampers next year some time, 38.5x14(I think) x 15
ok, I want to do a 4" shackle flip in the rear, plus some 2" springs(total 6"), then i want to add a 1" zero rate in the front,(to bring it to 5"), offset to move tha axle forward a little(I might replace the front 4" springs with new ones to correct sagging current springs, if needed )
will these tires clear with trimming?
I have a D60 for the front, and am looking for a 14BFF for the rear
also, with the 5", will I have the rome to go cross-over? or?
to fit the tires. Also
ALOT to fit 15" wheels on the D60.
