Thanks, I’ll keep that in mind. I am so used to working alone I wouldn’t know what to do with help![]()
Same here. When help is offered I get confused for a second.
I really like how the flairs accent the white. Perhaps a small lower rocker panel application of bed liner to finish it off? Mr. headlight looks out of adjustment btw. I went with the LMC replacements on my jimmy. Wasn't thrilled with the lights that came with even after the harness treatment so i plan on nailing down bulb numbers and ebay shopping for a HID kit. I also have to replace those 3 big ass (8") LaPaz series offroad lights with a 30" rigid led bar. It is just stunning the amount of light output modern day Led's produce...makes everything else look like turn of the century lamps used for the first automotive lights.
Yeah HID's in a lens not designed for them are really annoying and dangerous to other drivers. That and I don't feel people need that much lighting power for the low beams, there's a reason manufacturers came up with the idea of high beams. I'm going to do the same thing you've done Larry, HID's in the highs only, except that my auxiliary lights will also be HID.
He probably used an air hammer to punch the holes in the roof.
Cant wait to see what direction you go with it!
What are you thinking of doing with it?
Where did you buy the starter?
