Well, well, well! I popped the trans out Friday night and found that I had indeed installed the clutch disk in backasswards. Not sure how in the hell I did that….flippen idiot! LOL The release bearing was a casualty of the disk being in backwards, as a few pieces of it got broken off where it clips on to the fork. It was a cheap plastic bearing anyway. Not sure if it is a good thing or a bad thing but I got the trans out in under an hour. That is a bad thing because I shouldn’t need to know all the short cuts to get it out so quickly! LOL
Anyway, I was finally was able to take it on a test drive this morning and I am a completely satisfied camper! It runs identical to the K10 as I had hoped! Tons of power with Cadillac drivablity manors. No more idle flares, hunting idle, dying, jerky jerk operation…. blah, blah blah…. Ah, and having the low-end grunt to let it lug itself around is so nice. Best of both worlds. Sucks it took 6 months to get here but it was worth it in the end.
You’re all probably tired of pictures but these are the latest pictures with the final hose/harness routing and clipping. It is now DONE under the hood with respect to the 8.1L swap. Speaking of the hood, that is the last thing that needs attention….the hood needs adjusted badly! I’ll try to get some videos soon.
Made stand off brackets for the hydroboost hose from the pump to the booster. This is a GMT400 booster hose (those hose with the blue clamp).
Made another stand off bracket for the hose going to the pump. It has a p-clip holding to the stud to prevent the metal portion of the hose from vibrating resulting in fatigue cracks
Might have a leak here at the pump. Got to keep my eye on this. Didn't drip any over night after I wiped it off
Final Final!
This should be the end of the engine swap reporting for a while. Next up I need to adjust the hood, driver’s door and get after the horrible driveline angles causing major highway vibrations. Aiming to take it on a long roadtrip in May to the Overland Expo
