carpeonnel
Gotta a question about the stock prop. valve that's on the front cross member. Now I've replaced everything in the braking system (except for the mc, pb, and prop. valve) when I did my front and rear axle swap, and I'm still haven't a problem I was before I did the swap. Sometimes, whenever my K5 feels like it, it'll pull to the right when braking. Sometimes it's alot. Sometimes not at all. The only thing I can think to replace that I haven't yet is the OEM prop. valve. Could this be the culprit or is there something I'm not seeing?
