Propane injection, everyone read!!!!!
imiceman44
Hoarder extraordinaire
Lincoln, CA
Hey Guys
Up till last night I always heard propane injection only works on turboed engines.
Well last night my buddy Wes was reading somewhere that it can be done on a NA 6.2 and that bully dog has a kit for it and you can get 100HP extra with it.
Well he had a regulator from a Oxy Acet system so he put it on a propane tank, put the line in the air box intake, and went for a drive on a hill where he usually is lugged down to a max of 50mph in his crew cab dually utility truck.
Well the same spot with 5PSI of propane, he was going 70 and had to let off the gas because he was going too fast.
He experimented with different pressures and got pinging at 6PSI so 5 is max for this setup.
He's working on a better diffuser in the air box and some more testing and I will update as we get more but GUYS: start doing it, he felt the difference in the seat of his pants. He could feel it when he turns it on or off, he said litterally: "I had a squirel under the hood, now I have Three. :)"
More to come.
We want to dyno the setup when we get it fine tuned but for now, it's worth it.
I had always heard the same thing, until i started hanging arround the Diesel Stop. There are actually quite a few N/A guys over there running propane with pretty good success, but nobody has any dyno #'s yet for a N/A motor on propane. Ill be interested to see if your buddy puts his on a dyno and what the actual numbers are.
Diesel Stop is where he heard it and decided to try it last night.
I will make sure we tweak it right and then dyno it I want to see some numbers, and I will do the same on my perkins and compare. I also have a turbo 6.2 I am rebuilding I want to do the same propane injection too .
Also to note, when testing the other component that showed big improvement is temp, it used to go up on steep hills, now it's steady at low temp since it's running more comfortable.
joez said:
I would assume you guys played arround with this over the weekend, any updates?
No news from him yet, he hasn't called me since I posted here.
What did it do to the EGTs?
The propane is displacing some amout of air so it could potentially raise the EGTs.
He's working on getting a guage on, but now it's just running cooler so we're assuming it's not bad.
savagek5diesel said:
any word on the updates of this project?
No time, no money for guages so he's on hold for now.
ALl we got so far was steady engine temps, lots of power and better fuel economy. All this was noticeable.
It will be a while before we get further into this, but the source we got the idea from (diesel stop) has lots of feedback.
Hmmmm?
If this proves out--my 20lb propane tank wont see much B-B Q ing this summer!... :D kinda sounds like nitrous for a diesel! :laugh:
that is exactly what it is, i had read some about this a few years ago when they were offering kits for newer fords,
they needed to inlarge the exauset, but thats about it.
it rased combusatability, lowered emitions and gave more power, they said it did for diesels what NO dose for gassers!
my only question it, since you are entering propane into the clys and the air mix must be more volitle, so could this make the air mix ignight permaturly?
big_truxx said:
i just wonder if propane injection will decrease the longevity/reliability of the engine :confused:
Theonly way I would see it might if you end up with too much pressure or high temps.
My friend ended up with lower temps and I don't think you can get too much pressure with a NA diesel.
No more updates since the post was up, he is still working on a switch because it was pinging if he had propaneon and let off the gas.
I've been thinking about a way to use the propane tank that's already built in to my motor home and plumb it into an injection system. Wouldn't that be cool? Turn the stove on and gain 100hp! :p:
Found this in the FAQ section on the Banks site
Does Banks offer a propane injection system?
We've followed the interest in propane-injection systems for diesel engines, and tested several to see if they are a valid way of safely increasing horsepower. We uncovered a number of serious safety issues:
1. Propane injection is nothing more than a way to add more fuel to the diesel engine. Without additional airflow, that additional fuel delivery can produce excessive exhaust-gas temperatures that harm internal engine components.
2. When propane is injected into the intake tract, it actually displaces some air, further increasing the risk of excessive exhaust-gas temperatures.
3. Too much propane can cause detonation, which is very damaging to internal engine components.
4. Propane is commonly injected into the intake prior to the turbocharger. This means that propane is present in the pressurized intake air, introducing a volatile fuel in an air-stream that would not normally contain fuel of any sort. Turbo-diesel engines occasionally develop intake boost leaks, and when propane is present, a boost leak could result in the presence of propane in a heated under-hood environment. This is a great safety risk.
Before Banks ever sells a propane-injection system for diesels, these issues would have to be resolved in the course of our product development.
