Selling a used propane setup that I purchased last year from another member. Was told it was a GotPropane Kit but there are no labels and I don't have any paperwork to verify it is one of their products.
It came off of a running driving rig and worked flawlessly when pulled.
Comes with
- 2 - Tank brackets. 1 is near new except for some weathering. 1 has some weathering and the base has been trimmed with a plasma cutter. Bolt holes are still intact and the mounts are still usable.
- Mixer
- Carbuerator w/vacuum advance
- Pressure line (cut and crimped for a pickup w tank mounted in the bed. May have to purchase new line depending on where you locate the tank
- Propane supply line to carb
Only thing you will need to buy will be the fitting to tap into your heater core line, some hose clamps and a vacuum advance line for your distributor.
Asking $750 shipped to your door.
If your local to me, I also have 4 forklift propane tanks. 1 is full of propane.
Asking $100 for the tanks.
Please email me for any questions as I am hardly ever on here anymore.
james dot g dot [email protected] (the "dots"are ".")
Comes with
- Mixer
