Here is my setup. It uses dual Impco 425 carbs, dual model L vaporizers, and VFF 30 vacumm lock off valve. The intake is a edelbrock dual quad intake. I got a distributor is an HEI off of Ebay. The heads are Edelbrock Aluminum Performer RPM heads. For the cam I just called up Comp cams and told them what I had as far as Drivetrain and what I use the truck for. They gave me a cam with 230-234 duration and .470 lift. I thought it was a little big, but have been told that more duration would improve power. The power is good to 6000 RPM, probably good to 8000 RPM If the motor could handle it. The smell of the propane doesnt bother me. I am not sure If I am running rich, but the propane from my exhaust doesn't smell so bad like the forklifts from work.
I am very pleased with the propane setup. Starts right up every time. The carbs and vaporizers are very simple. You only need a flat head screw driver to rebuild them. I run a 80 gallon tank which is ends up being a 60 gallon tank because you can fill them to 75%. The only draw back to propane I have found is the fueling stations. Its okay locally, but when you go out of town its a little harder to find them. On anything other then a truck, its going to be difficult to get a tank to fit. Not impossible, just have to search a little more.
I also put a fuel sender on the tank so my stock fuel gauge still works. Since the tank can only be filled to 75%, it reads full at 75% and empty at 0%.
The price is probably the best benefit as Its a $1.25 at Flying J if You have one of there rewards card(which is free by the way) and the guy that works there said the price hasnt changed since he started there 4 months ago.
www.PROPANEGUY.com is the place to go if you want a good quality affordable system that uses no electronics what so ever. Thats where I got my whole system.
www.gotpropane.com would be the place for a good quality expensive system.
Here are a couple good links. The first one has hit its limit on views, but will start over in a new month so visit that one for sure.
http://lonestar.texas.net/weblock.html
http://www.impco.ws/
http://www.alternatefuelsracing.com/
http://www.wps.com/LPG/index.html#INDEX
http://www.mergetel.com/~fraso/RasoEnterprises/Propane-Model425.htm
http://www.gasresearch.com.au/
http://www.patooyee.com/ Click "Technical", then "The Pane"
