2Fst4U
Registered Member
Looks like my brake proportioning valve is the issue. Does anyone know an aftermarket replacement that will work with an 89 Jimmy. The vehicle has front disc and rear drums. The vehicle does not have abs or the load sensing proportioning valve. The original valve is located on the cross member in front of the motor, not next to the master cylinder. I would like a valve that will work with the stock setup and maybe the possibility of having it work when I swap axles and do a rear disc conversion. If you only know of an OEM replacement that would be fine too. I just need to get it up and running for emissions. I also don't want to have to do any brake line modifications. Any suggestions?
