The proportioning valve leaks on my '74 K5 - why and how do I fix it?
Background: I have the usual story,the brake fluid was not changed every 5 years. Last year I replaced the master cylinder and rebuilt the calipers and rear cylinders. In the process the proportioning valve was activated to shutoff when I pressed the brakes without one of the calipers on the rotor. It reset and soon thereafter began leaking. It is a slow leak and over the last 12 months I have only had to add brake fluid twice and both times it was maybe a half-inch down in the reservoir. It is still a leak and it leaves a spot of brakefluid in my parking spot. So far all I have tried is to smack the proportioning valve with a ball hammer a few times to 'ring' it and loosen the crud. It stopped leaking for a few weeks but then leaked again. The brakes work fine and they bleed fine. The Brake light is off but I also don't know if it works - I need to take a multimeter and see if the proportioning valve is still activated. It sounds like the story is these fill with crud and rust from never getting flushed. Then if the proportioning valve activates it shifts the plunger into the rusted bore and tears the seals, then it forever leaks out the passenger side weep hole.
Before making this post I did some quick research - these are the posts I found relating to leaking proportioning valves:
My options:
Any help you can provide is appreciated.
- right here at coloradok5.com, this valve was not leaking it just had the light on - working properly, there was a pinhole leak
- another coloradok5.com, leaking valve, no solution found
- another coloradok5.com - dyeager535 said to get one from junk yard, poster did and that worked fine
- over at nastyz28.com, they found that the brass replacement proportioning valves all leak
- on the same nastyz28.com thread, in posts #21 through #33 the supplier of rebuild parts is trying to make a rebuild to stop leak on the OEM unit, looks like the exact same unit I have - he never posts if he assembles a rebuild kit
- at chevelles.com a parts supplier posts here and defends the brass replacement valves and claims 1% of them leak and come back
- the Pick-n-pulls in my area has three C10 trucks and no blazers - I could go grab a proportioning valve from a C10 and hope it is the same internally - if I knew the range of vehicles the same proportioning valve was used on I could pull from a larger range of vehicles
- rebuild kits sold here https://www.musclecarresearch.com/ but not for '74 K5 proportioning valve - the guy in the nastyz28 thread is the supplier
- http://www.gmpartsonline.net/ part number does not exist and the online lookup does not have 1974 as an option
- http://parts-catalog.acdelco.com/catalog/stock_check.php part number does not exist
My options:
- pretend it is not leaking and go on with my day (did this for 12 months without luck)
- smack it a few times with the hammer again and hope for the best - loosen all four bleed valves and stomp hard on the brake to flush.
- take it apart and look for matching o-rings at Napa on a Saturday (then hope it goes back together - the word is it cannot be reassembled without some unknown tool, per nastyz28 post)
- buy a brass replacement and hope I don't get a leaker (everyone sells them - typical is carolinaclassictrucks.com - but the consensus is they are all from the same overseas supplier)
- ask musclecarresearch.com if they know of rebuilt OEM units or put together a rebuild kit (sent them an email through their website)
- buy this one from ebay style ebay-n-pull
- hope to find a good core at pick-n-pull (maybe I can get some vortec heads at the same time and look for q-jet parts)
