I have this AC Delco Proportioning Valve (Part # 172-577) that works fine except the "O-Ring", if you call it that, is split.
Does anyone know where to source parts for these things? I assume they were meant as a consumable that should be replaced if a failure occurs as I can't find anything when I google the historical documents.
Also, anyone know how to remove the other end of the valve that has the rubber protector on it? I don't know if it screws out or if it is press fit (doubtful as I would assume pressure would push it out).
