CUCV2
5/4 ton fun
Does bump steer have anything to do with this? When you hit the brakes, the front end will dip some. This will change the geometry of the stock push/pull set-up. The cure would be a cross-over steering set-up which would mean throwing out the swaybar. I personally like swaybars in a daily driver and would prefer to keep it. Just my .02 cents here. Curious what others think of this theory.
this will hold pressure and burn up brakes and make a pull. and or restrict flow and not work right.
