I just installed a new pump because the old one was making a good bit of noise and it appears I have very little steering after one wheeling trip. I'm running a 36x12.50 tires on a D60 with crossover steering. If I jack the axle up to remove the weight off the tire It will turn lock to lock no problem. So I'm not sure not if the pump or box is the problem. Any ideas?
