Psc assist setup
Smokinthehippies
3/4 ton status
Millard, NE
Looking fr a complete kit to run.
Want to run 40s on the street. I'm guessing 1.75" ram would be the best mix of speed & power.
Any thougts?
Also looking for a price shipped to 95054 as well as a lead time to recieve after ordered.
Thanks.
Uh, better make that two quotes Chris.
My box is tapped but I need everything else. Running 39's with reverse high steer and I can't turn worth a crap when the front is locked in.
Pump, reservoir and ram are the main thing. I can get lines made locally. I'm not sure if they come as kits or individual pieces. I'm guessing you can give a ball-park quote without knowing the stroke.
93704 zip code. Thanks.
Any chance you can make it 3?
I've got crossover and high steer on a first gen. Can you quote me for everything, and just the tapped box? May not have the coin to do everything right now, but my box is sloppy. Running 39's with mostly street driving. Shipping to 44303. Thanks!
quote please
I have crossover. I need tapped box and entire hydro assist setup. Just trying to get an idea. Quote for 36362. It probably will be a bit before i can take the plunge though.
Chris,
I have a feeling I need the same thing, but I've been avoiding hydro assist for a while. If you guys have any not so super secret recommendations for getting the most power out of a non-assist system with crossover(new pump, modified box?), I'd be really interested in trying that out before I went ahead with it.
Chris,
You could go to a longer steering arm, and you would get more steering force, but you'd be losing steering angle.
You can also go to a higher pressure/flow pump that would buy you some extra power, IMO that's the way to do it if you aren't going to dive into hydro assist. And, if you get a pump with a bigger reservoir, you can still use that same system if you upgrade to hydro assist later.
