PSC hydro assist, PSC 2wd box (flare style), lines and drop pitman arm.
twoslo4five0
3/4 ton status
Living in a dump, VA
Like the title says, PSC 2wd box (not much run time) already ported for hydro assist.
Lines, I have made at napa here locally. 3/8s I think, fittings match ram and box.
Psc ram, 1.75x8. I used it in both low and high steer applications. You will need to buy a set of tabs or make them for your axle. Comes with heims.
drop pitman arm, just the standard drop pitman arm tapped for 1 ton tres.
ord bolt in brace available as well
I also have 3 I ton tres in bungs (i just cut the tubes for heims). I will throw those in for 20 bucks If someone wanted it.
600 for the stuff above, 620 with the tres. Im willing to ship and can for 50 bucks just about anywere in the US as it will be 2 flat rate boxes. Located in prince george. Still on truck currently will be removed on monday of next week.
text for pics 8zero45one36zero34
