PSC Steering Box
Just2Much19
Roseville, CA
I have the steering box ($390 from ORD) and the drop pitman arm setup for crossover steering ($75 from ORD). This box came pre-tapped for Hydro. This came off of a full size blazer.
$350, located in Sacramento
Was purchased from ORD and is lightly used.
what years is it ment for? (flare or 0-ring style)
ive got one of these boxes on my truck and they are sweet!
Shipping to 91345? So. California,
Is anything wrong with it?
Are the threads were the bolts attached stripped? Did you run anything other than
power steering fluid in it? Need to ask someone put brake fluid in a gear box here on CK5.
Wow they did? Maybe they should be banned from working on cars! :screwy:
It was pulled out of a fully functional Jimmy that I parted out and only wanted the axles. No treads stripped, only power steering fluid ran through it. Nothing wrong with it as it worked when pulled.
Shipping is about $25, and then if you want insurance for $350 it is another $5.
you can convert, im running the older flare style in my '88, its just a matter of swapping out the adapter in the power steering pump.
You can also get re-useable fittings from PSC that will allow to run the different ends and just carry a piece of rubber hose for spare.
