PTO question
Hazy
CA
i searched around but couldn't find what i was looking for. i wanted to no what i need to use my sm465 PTO cause i want to run a winch. thinking about a MM 9000 or something. but i have no clue how to run it if i even can. some imput would help thanks!
I came up empty handed when I was looking last year. We have a place here in Wichita that supposedly carries a PTO adapter for the SM465, but I never priced them cuz I lost interest. Might try eBay. I've seen some off-the-wall items for sale, might find your PTO.
okay so that bolts on to 1 of 2 spots i have on my sm465. ill do some research on that then. thanks!
after you source the correct pto, you will still need a hydraulic pump, resiovor, & hydro lines. will also need linkage & shifters to shift the pto on & off.
there are a couple styles of pump too. there are direct mount that bolt to the pto box & then there are remote mounts that need a driveshaft between the pump & pto.
yeah i just talked to my uncle he sid he used 3 cv joints and the driveshaft made it to the front. i want to fit the MM9000 in diy4x's new bumper but idon't think it will fit. i might end up making my own bumper
