PTO with a doubler...
Michk5
Misawa Japan until December...moving to Wichita Ka
Is it possible?? I want to run the NP205 clocked 2'' up and I'm thinking the PTO winch set-up I have won't work. So can someone running a clocked doubler (and not clocked) take a look for me and see if it could be done :D . Also, if it won't work, and I have to go another route for a winch, how much is the NP205 PTO, shaft, and Ramsey 8000 PTO Winch worth??
Thanks in advance
Matt
Thanks in advance
Matt
it should work, exhaust clearance and crossmember clearance are the only things, but that is simple enough the fix, you will need to leave the 203 in gear and the 205 in neutral for just pto output
dont see any problems.
i bought a 205 pto box, and winch off a member for 250 bucks.
not sure if i will end up useing it might see it soon
correct me if i am wrong... but isnt there a pto port on the range box of the 203? i dunno.. i have had my doubler for 7 months almost and have yet to put anything together... letalone its been a WHILE since i have touched a K truck
Grant
Grant
I think that's what the original poster is talking about, using the 203 gearbox to run the PTO.
I might be wrong, but isn't there a pto slot on the 203 as well? Then the clocking arrangement shouldn't matter.
Michk5 said:
Thanks guys for all of your input. It's not for sale I just wanted to know what it's worth!! :haha:
Matt
aint worth nothin.. give ya fiddy sent fer it... found a bare spot on my garage floor.. NEED TO FILL IT!!!! :haha:
