Pulley/belt issues. Please help me
Someone was definitely mixing things up on this truck. The core support has a 1988 emissions label. The engine has center bolt valve covers.
I just want to figure out what I need to make everything work without spending 2k on a complete pulley system
I’d bet your whole set up is from an ‘88+ 3/4 or 1 ton truck. My ‘91 had a single serpentine belt set up with aluminum brackets but a friend’s ’88~’89 V3500 had a mixed belt set up like that.
My 91 crew cab had this setup and my 89 suburban as well
I found this vudeo this morning. It shows how it should be set up. So, I guess my ac compressor is back too far by about 1 belt groove.
