elks
I am curious how you all go about pulling off the front rotor once you have all the hub guts out. I usually just grab the rotor and pull from different angles slowly working it out. In the past it has worked just fine, however last 2 times I have taken apart some hubs that had not been off for a while and the inner bearing stuck and then ate up the inner seal. Is there a way to press it off nice and easy? Or do you just pull it off nice and easy?
