Well it looks like I flattened the camshaft in my Blazer's motor with my mods from last year. So the motor is coming out, getting cleaned up...and getting a roller cam.
didn't you put new heads on a existing short block?Well it looks like I flattened the camshaft in my Blazer's motor with my mods from last year. So the motor is coming out, getting cleaned up...and getting a roller cam.![]()
and the one piece rear main seal isn't nearly as prone to leaking oil.
Martin
I like you Craig. Your crazy, but i like you.
Because he is looking to go roller cam. The one piece rear main seal engines are roller blocks, and the one piece rear main seal isn't nearly as prone to leaking oil.
Martin
I'd also very, very highly suggest you take the whole engine apart and clean every single oil passage, bearing etc. All that glitter that used to be your cam lobes cannot be good for your bearings... I wouldn't trust the oil filter to get it all, plenty gets sloshed around by the crankshaft so it'll be everywhere.
Offtopic...but I had to say it... Theres a effing dart in your neck!
