Jester1
So if I get my new tranny this week I was thinking of doing the swap this weekend and I couple of questions came to mind.
Should I pull the tranny and t-case as a whole unit as I will be replacing it with a tranny and t- case or should I disassemble and remove/replace seperatly. I do have floor jacks and a tranny jack.
While I am there should I look at replacing the bolts (bellhousing, crossmember,etc) and only thinking of this cause not sure what stresses these bolts may have seen.
Should I replace the mounts as it has been possibly 40 years that these mounts have been in place. Although I want to replace all the mounts down the road as in the engine, body, tranny when time and funds are more available and just really want to see this rolling. If the PITA factor is to great for later I will see about doing it now.
Part of the plan is to run the tranny jack up and strap tranny down with ratchet staps, unless there is a better way, remove the bolts, lower t-jack then jack up front of rig then pull it out from under. I know the th350/203 combo is heavy so was thinking keep it low. Then reverse for install.
It been years since I pulled a tranny and I don't think I have ever pulled a combo out of one of my rigs, so just looking at some of the possible pitfalls in store. Any heads up is appreciated. Thanks.
