marine_enlisted
Got the D60 in today, everything went together perfectly. Installed braided front hoses, and got the brakes bled out good, but the pedal is real low. I still have my stock 1/2 ton master cylinder in there. I am going have to put in a 3/4 or 1 ton master cylinder to get the pedal up, especially when I put the 14 bolt FF in with the rear discs. Is there a difference between 3/4 an 1 ton master cylinders? I've heard that the front and rear lines will need to be switched around when going to 3/4 and 1 ton. Can you just re-bend the lines and make them work? /forums/images/graemlins/ears.gif
