Put these modifications in order....
78Suburban
Georgia
ok guys, the next thing on my list is to get the burb lincon locked in the rear. After that I want to do the disk brake conversion.. After that, there's several options:
Beadlocks (either DIY, or try to find recentered h1's)
crossover steering
WFO concepts DOM tie rod
high lift jack
electric air compressor
heavy duty diff cover for 14ff
very simple cage made from HREW
What order should the above go in?
7.....Beadlocks (either DIY, or try to find recentered h1's)
2.....crossover steering
3.....WFO concepts DOM tie rod
1.....high lift jack
4.....electric air compressor
6.....heavy duty diff cover for 14ff
5.....very simple cage made from HREW
i can agree with that...#5,6 and 7 could be in any order tho
Hi Lift #1
I'd save the crossover project for your Dana 60.
I wouldn't use an electric compressor, definitely go York.
Big tie rods are always good, and should mostly swap over to your Dana 60.
The rest you can just do when you feel like it, or can afford it.
1.....Beadlocks (either DIY, or try to find recentered h1's)
7.....WFO concepts DOM tie rod
5.....high lift jack
3.....electric air compressor
4.....heavy duty diff cover for 14ff
6.....very simple cage made from HREW
I went ABC order:D
crossover steering
high lift jack
1. Cage
2. Hi-lift
3. HD Cover
4. HD tierod
5. Crossover
6. Beadlocks
7. Compressor
I personally think Cage should be #1. Safety should be #1 priority. Everything else comes afterword. I wouldn't do crossover or hd tierod until the D60 is ready if it will be ready soon. The HD tierod would have to be shortened and the draglink would be shorter also I believe. The knuckles and steering arm would be useless except to resell for used prices.
Harley
78Suburban said:
7.Beadlocks (either DIY, or try to find recentered h1's)
3.crossover steering
5.WFO concepts DOM tie rod
1.high lift jack
2.electric air compressor
6.heavy duty diff cover for 14ff
4.very simple cage made from HREW
I agree with some of the suggestions if you are going to go D 60 keep your crossover conversion on the half/ three quarter ton stuff as cheap as you can.
Jack, get you out of many situations and stucks.
Crosover.
Beadlocks, aired down tyres will get you out of a lot of trouble too.
Compressor to air up!
Cage, as now you can get out of trouble you may push your luck a bit more.
Tie rod as you're getting intpo trickier situations.
Diff cover for same reason!
