puttin my 60 back together
muddybuddy
1 ton status
Northern, VA
well i finally got my d60 back from gettin geared. i need to put everything back on from the knuckles out. what is the order of all of it? its been so long i forgot :doah: thanks!
i looked at the bible and it kind of shows the order, but its hard to see some of the parts.
If you look on the first page, BillaVista lists the differences between the 60s. One of the diff's is how the brake spindle etc goes on. It's been a while since I tore into one, I forgot too!!! This help??
7) The Chevy/Dodge caliper mounting bracket bolts on AFTER the spindle, as in knuckle-->spindle-->caliper bracket, whereas the Ford mounts the caliper bracket between the knuckle and spindle, as in knuckle-->caliper bracket-->spindle
you will never figure it out. send it to me to add to my colection.
knuckles / shafts / rubber seals and bronze washer on the stubs / spindles / caliper bracket / dust shield / little dust shield / washers and nuts / then hub/rotors / then spindle nuts and lock waser in betwen the 2 nuts / lockouts / then calipers in there somwhere / then wheels with lug nuts.
yep i got it!! just gatta pick up my new rotors tomorrow and im goldin! thanks guys
