Putting my money where my mouth is
K85 Octane
People Fatigued
San Bernardino CA
DIY4x poly bushing "race" engine mounts. Installed back in 2012, maybe 2013. Most of you know know Bender and know it wasn't a mall crawler.
Factory rubber AcDelco (or Depo, can't remember) transmission mount. Also installed in 2013ish.
Same set for 10 years
I have mentioned this many times before...you don't need to match your trans mount's material to your engine mount. Not necessary. I understand why it's believed that but you don't need to spend the money unless you want to. I like the factory mount, leaves some wiggle room and vibration dampening.
Rubicon, Moab x4, Pismo dunes x2, Glamis, Hungry Valley x:dunno:, Azusa Canyon x:doah::dunno: and so on. I'm not a mad man with the throttle but I've also never "thrown away bald tires".
See, right there... :haha:
The working theory is that using poly on the trans, and squishy stuff on the engine can break cases. You did the opposite, which nobody seems to argue against. To form a real consensus, everybody submitting data would have to report which (if any) of the braces were installed.
Exactly.
