PWindow motor bracket
Artemis Entreri
Staten Island, NY
Need the 4 bolt bracket that holds the motor to the regulator in a power window system. Trucks a 91,drivers side if it makes a difference, anyone have one??????
-Steve-
Think I still do, I'll know by Wensday. Comes with motor if it's still around.
I have it. I'm parting out a set of power doors for spare parts on my '83. I doubt I would need the brackets. I'd take $15 shipped for it.
Also, I havent taken the regulator out yet, but looking at the LMC pictures, I cant figure out for the life of me where or how the bracket bolts on, anyone have any pictures of it beore they put it back into the door or something?
I haven't taken the doors apart yet, so I can get pics when I disassemble. I'll PM you my paypal info.
Not to rob the post but I have a few out and you might save a few $$ on shipping from MA to PA>
Here is a pic of my drivers side power motor/brackets... the motor bolts directly to the regulator with no extra brackets. So I'm not sure if it's exactly the same thing your looking for?
Can you get a picture of it flipped over so I can see the motor? I cantsee how it mounted there, andthere should be a 4hole plate that goes in between them, does anyone know what im talking about?? LMC sells it to you when you buy the motor.
Um, I got two new LMC motors when I redid my truck, I just unbolted the old and bolted the new on. I don't remember anything extra. Unless they changed their replacment motors since then
I'll take a closer pic of the motor flipped over, but there was no plate in between the motor and regulator.
Yea, I think so, from what I understand now, they are riveted stock, need to drill the rivets out to get the motor off, and when I use it, I just need to use bolts.
I'm going to send you a refund for now... I don't want to seperate the motor from that bracket as would need it to use the motor on my truck.
Then again... after I swap out the bad motor I will probably have a burnt out motor I can sell you for the bracket. I'd do the same price, but you will have to wait a week for me to get that motor swapped.
