gerber boy
Registered Member
hello all, the problem i have come across is this buddys truck 85 3/4 with 6.2. his power steering pump is constantly squealing at low speeds when we turn the wheel. basically when stopped if we go to turn it squeals and we get armstrong steering.
he has replaced the pump and steering box, we replaced the axle shaft u-joints (which helped some, they were seized) and when we had it all apart seperated the tie rod and could turn both hubs easily by hand, so i don't think it's a seized ball joint. the drag link ends turn fine but we can't seem to find anything else...
Could it be the hydroboost? how would you check that?
and yes before someone says it the belts are tight
