q for those with 56" fronts
originalspanksta
Philadelphia
What is the concensus on what leaves to pull? I have a set to put in my SAS to replace the 52's i have there now (need more firewall clearance.)
stock 3/4ton leaf packs with 8 leaves(i think) and an overload.
I had planned on yanking the overload off and a couple of others, but if you guys who have had 56's on for a while could give opinions as to which ones, i'd like to avoid the trial and error phase of continually piulling the packs apart.
TIA...
Matt
I went down to 5 then added two to get 7. My springs must be shot though. I have about 4" of lift and like 2" of that is spring. So, I have like 2" of uptravel on a "light" day.
I'd probably start with 7 and just remove leaves as you go. It's not that bad to do. All you've got to do is half-assed tighten up the U-bolts and stick the bolts through the spring eyes and call it good. If you happen to have a buddy you can just lift the rig up using a Hi-Lift and pull a leaf out without taking the eye bolts out.
