When setting the choke as the rebuild kit says....Turn counter clockwise until choke plate close then turn clockwise until the plate move 1/16 off the back of the air horn. When setting to this setting it seems as if there is to much spring tension when I mechanicly relase the choke. The reason I say this is because it appears to lock out the secondary's, because the spring tention holds the lever up just enough where the secondary pin does not clear it. If I set the choke with less tension the secondarys open correctly however I do not know how the choke will work under cold conditions.
any help is appreciated.
