hi all
when cold it will start with only one try
but if it is hot it wont start unless I pump the pedal several times
it is a 1985 K20 with stock 350
the chock in the Q-jet wasn't functioning properly so i adjusted it to be open (vertical) all the time and blocked the vacuum hose going to it
also last time when I went to the dunes the idle started to be rough
what should I look after
and I have a brand new EDL-1407 750cfm with off-road needle (not installed yet)
is it better to use the edelbrock than fixing the Q-jet
thanks
thanks
