I have a 86 k5 with a q-jet that has vaccum secondary. I have been wondering for a long time if the secondary is really opening at wide-open throtle. From what I see the blades open for sure due to the mechanics and linkages, whats in question is the top butter flys that allow it to breath. From what I can see they are not opening. I put a long piece of vaccum line to the back of the canister that that operates the linkages. This cannister holds vaccum and also pulls the mechinism towards the fire wall. There are two linkages attached to this mechinism, however when I have the vaccum canister at full stroke none of the linkages are moved and if they did it would seem that they would be moving them the wrong way. The mechinism that is attached to the canister is sloted, hence thats why the linkages never moved. If the linkages did move it appears that it would hold the top butterflys closed. So I wonder the following:
1. am I missing something
2. was this put together wrong by someone during a rebuild
3. is there a different way to test what I am trying to prove
It has always been my experience that when a four bar opens you can really hear the transition in noise even if the truck does not have major horse power I would assume the same transition in niose would occur. When I mat it there is zero difference which is why I think the secondary is not breathing and the metering rods are not being lifted to allow for more fuel.
thanks
thanks
