Q-jet questions
nvrenuf
Holy crap, it's running!
Mobile, Al.
Ok, I'm new to the q-jet world so bare with me...
Which port should I use for PCV, front or back? I should have taken a pic of the underside, the rear is open thru the baseplate into the intake plenum while the front disappears into the baseplate.
I feel stupid for asking but I've run Holley's and push in valve cover breathers for 20 years so I'm not sure. :dunno:
Both are full vac, rear for power brakes front for pcv.
Depending what set up u have for power brakes determines what fitting to use In the tapped hole.
