handloader90
Building!
First off, what in the hell is that round thing? It has a cable coming from it that attaches to the throttle linkage. It connects to this little control unit thing in the right side of the second pic, the unit was mounted about dead center on top of the driver side inner fenderwell.
What purpose does all of this serve and is it necessary? I plan on removing everything non essential from the engine bay. I plan on only having the engine, brake booster, radiator and such. Just enough to make it run.
Is the choke on this electric or manual? No choke cable in the cab. I've got another Q-Jet sitting in the garage that supposedly came off of an El Camino and the choke is the exact same. If it is electric how do I get some current to it?
Another question, all of the HVAC and emission junk is still hooked up and running, I'm going to remove all of it and would like to know if I can just put rubber caps on all of the vacuum ports on the Q-Jet once all of the vac lines are removed.
Last question... what is hands down the best replacement intake for a Q-Jet? MFG and model info please.
