I have a 1979 K20, 350 ci 4 bbl QuadraJet carb, SM465, 153,xxx miles on it. The engine and carb appear to be all stock, unmolested and unmodified. For its age, the truck runs well. I recently replaced the distributor cap, rotor, wires and plugs. It starts and shuts off fine, but has a rough running spot just off of idle. The colder the weather gets, the worse the problem.
When starting the truck, it will run rough (miss) for a few minutes, and then smooth out and go into it's high idle mode. After the truck fully warms up and the idle speed drops down to normal, the choke is fully open and ready to go. That seems to be the point when you give it a little gas to move forward, that it wants to bog out, unless you feather the gas somewhat. This problem fades a little bit, especially if the truck is driven for a longer period of time. I have sprayed the carb with cleaner, while the engine was running, in an effort to find vacuum leaks, but there weren't any. The spark plugs appear to be slightly colored due to oil (high mileage), not overly rich or lean from gas.
Other than rebuilding the carb, is there some external adjustment or part that can be replaced to fix this rough running problem? I hate to pull the carb and rebuild it, I have never had a fully successful Q-Jet rebuild work perfectly.
What do you Q-Jet experts think?
